Coffee brewmaster released in 2013. The Keurig K40 is a k-cup compatible coffee maker.
Why wont my keurig make a full cup of coffee?
hi … i have a keurig k40 …that every couple months decides to not make a full cup of coffee … tried everything shown in info i seen on this site…last couple times i had this problem …on the top theres a check valve that i took apart ..cleaned etc and watever i actually really did im not sure ..but works than for a month or 2 same issue …would it help changing check valve ? or would this k40 have a solenoid that could be causing issue ?
Hello, does this issue happen when you use a K-Cup or do you use one of the reusable cups?
i would say it happens with both k-cups and reusable cups ...also if i just fill a cup of hot water alone .. does this as well...
From what I can gather it might be that the needle that is used to puncture the K-Cup might be dirty. You can take a paper clip and see if that will dislodge any grounds that might have built up. Otherwise I would check your water pump, as that might be causing the issue.
i have cleaned needle as well ...still causing issue .... put water pump in vinegar still giving issue ...put a dfferent water pump from a different keurig on there ...still giving that issue so im wondering if it could be a solenoid ?
@norbie I would definitely try that next and see if that has an effect on the issue. Thankfully a replacement part doesn't seem to be insanely expensive if you want it brand new.
Jeff crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 442
