Hi @sobepapi ,
The wiring diagram in the washer’s 8183018 Tech Sheet only shows where the power gets to on the control board and not a circuit of the board itself. (see p.12)
There is a won’t power up test/check troubleshooting guide on p.13 that may help.
If it is determined that the control board is the problem and not the UI (user interface = control panel) or inbetween - harness connections etc, and you can’t see or find anything obviously wrong on the board, the part number for the control board is 8183257 (supplier example only). Search online using the part number only to find suppliers that suit you best.
If it is another component that is the problem, search online for 11049972600 parts to get results for suppliers, find the part on their website and then find the manufacturer’s part number i.e. Whirlpool, usually listed when you click on the part, and use that part number to get results for more suppliers of that part that may suit you better.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
crwdns2944067:04crwdne2944067:0
Hi @sobepapa,
What is the model number of the washer?
Here's how to add images on ifixit. Adding images to an existing question
Don't load too many as it may confuse. Only load the more relevant ones i.e. close up of control board area around where the power first connects and close up of control board itself.
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Correction: *held power button for TEN seconds
crwdns2934271:0crwdnd2934271:0 Jorge SobenesDesme crwdne2934271:0
Thank you @jayeff! Posted 2 pics. From the Landero begging washer’s door: Mod 110.49972 600. Ser CSU1105010
@sobepapi
OK I got your comment now will get back to you soon.
You were right, the ifixit iRobot thought it was spam because it sometimes thinks long numbers i.e. model numbers are phone numbers and deletes them.
I've reopened your comments and deleted the duplicates. This will restore your lost reputation points on ifixit (-100pts for each deleted spam post) and also teaches the iRobot a bit more.
Moderator
