Peugeot is a French automobile manufacturer founded in 1896. Peugeot is associated with the French firm Citroën and builds vehicles in Europe and Asia.
crwdns2934591:052crwdne2934591:0 crwdns2934593:0crwdne2934593:0
airgbag error, four doors and trunk open, brake light on 407 peugeot
hello every body i have 407 2.0 hdi with EW10A motor
The flasher lights always stay on and do not go out even when the car is off.
I have airbag error too
and error that all dors and trunk is open Although they are closed.
The brake lights are also on when the switch is opened
No error is displayed when I turn on the PPS or other diagboxs.
1) The car thinks that the doors and the boot are open and central locking won't lock the doors, the locks pop right back open when tried to lock. When the engine is started, the trip computer gives a message "doors, boot and rear screen open".
2) Seat belt warning light stays on even if the belt is fastened.
3) Hazard warning lights go off randomly, for example when trying to lock the doors from keyfob or straight after re-connecting the battery. Also happened once by itself, when the car was standing on the parking lot. Disconnecting the battery is the only way to make them stop. Sometimes the hazard warning lights are accompanied by brake lights as well.
4) And yes, the boot opening doesn't work either...
Update (04/13/2022)
hello guys @jimfixer @brettfastone_ an other
I solved it with new install BSI.
BUT BUT BUT
Problem returned after one month again.
I didnt do anything!
Please help me to solve it without change and buy new BSI its too expensive.
Has this car been in deep water? This sounds a lot like water damage. Have you tried resetting the PCM ? To reset the PCM disconnet the battery and then turn on the headlights on high beams . This will discharge any residual power in the PCM . Leave the car like this for an hour then reconnect the battery and hope for the best .
crwdns2942205:01crwdne2942205:0:
It has not been in any deep water.
But to be sure, I dried the trunk completely and checked the electrical part under the spare, which was OK.
I also reset PCM, but again nothing happened
It sounds like perhaps a fuse has blown and will need to be replaced before resetting anything and if all the fuses are ok check all the globe's starting with the 4 indicator globe's (sometimes the main computer is affected by an unsteady electric current and this causes havoc with the entire electric system) I hope this solves your problem , please post an update, informing if your problem was resolved.
Update (05/04/2022)
The BSI unit is basically a computer which handles a multitude of functions such as odometer value, central locking, lights and immobiliser. Some later Bsi units are liable to corrupt their own software program if not “woken up” in a specific way after programming keys or battery disconnection.
1. leave key in off position in ignition
2. Put the driver’s window down, lift the bonnet and ensure all
equipment is switched off.
3. Ensure all doors are closed and remove key from the
ignition.
4. Wait for 3 minutes, disconnect the vehicle battery and wait
15 seconds.
5. Reconnect the vehicle battery, wait a further 10 seconds (do
not open doors.)
6. Switch on the side lights through the driver's window.
7. Switch on the ignition and check system’s functionality.
8. Hold lock button on key down for 10 seconds.
9.remove key open & close door test central locking system
10. Start the engine and complete the system’s check.
Failure to follow this procedure could result in incorrect operation of many
BSI related items.
It did take three attempts following this procedure before it worked.
crwdns2944067:07crwdne2944067:0:
All fuse checked and OK.
I didn't understand what you mean? " all the globe's starting with the 4 indicator globe's"
I send an video of my problem
https://drive.google.com/file/d/11QdVCDG...
thank you for your time
I'm sorry for the confusion I'm from south africa and here we call it the indicators I'm not sure what you would call them where you are from. But it's the flasher lights used when indicating the direction you are intending to drive (So for example when stopped at the intersection and you want to turn left you would use the left turn indicator ) I hope this clears up the confusion.
I hope the previous comment cleared things up but just in case you still not sure. Just check all globe's of the car this includes headlamps and taillamp and any other lights on the vehicle. Again sorry for the confusion I hope this clears things up please let me know thank you.
@brettfastone_ please read the subject again lights isnt my only problem. all off problem is show suddenly.
hi Omid yes I understand that the lights are not the only problem. i only mentioned the globes because it sounds like there is an electrical fault and checking the globes and fuses is part of the fault finding process.
crwdns2934275:02crwdne2934275:0
Omid Ahmadyani crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 753
