Analog still drifting after replacement
I have a black and white camouflage ps4 controller.
Most probably it is a CUH-ZCT1E model.
You can see the right analog is offset from the centre in default position.
I have replaced two times the entire analog module, but the right analog is still drifting to the same direction like before.
What could cause this?
I don't think it's likely that both of the analog module I've soldered so far are faulty, and drifting to the exact same direction.
Is it possible that I have damaged something on the PCB during assembly, and that is causing the analog to be off-centered?
Thanks in advance :)
