Smove mobile battery replacement
I need to replace the battery on my Smove Mobile gimble device it is a Howell 2x902360-1300mah 7.4v 9.62wh battery I need to find a suitable replacement either the same battery or an except-able replacement. I’m fine with soldering the terminals if I can find the same form factor battery.
I am curious if you found a good solution for this?
@grayraver See oldturkey03's answer
How did you get the SMOVE apart? I have the same issue and want to bring mine back to life
You can tape two of these together and solder the batteries onto the wires coming out of the connector in the same way the old batteries were connected to the connector.
Do i need to connect with a parallel connection?
@starsoldier420 pretty common battery pack on RC equipment. You should easily find a replacement at sites like this. All you would need to modify might be the connector.
Randy Northrup crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,091
