How to hard reset jbl tuner 2
My jbl tuner hang. I can't power down or up. Pressing button doesn't work.
crwdns2944067:04crwdne2944067:0
Masalah saya cara ngilangin MCU UPDATE di jbl saya gimana mas,soalnya kalo ada tulisan itu speker saya ga berfungsi,makasih
Dear team,
i have the same issue, jbl tuner 2 won't turn on, where i can find the file to upload?
Mijn display is niet leesbaar , licht op maar niks te lezen
mijn display is niet meer leesbaar
crwdns2933315:08crwdne2933315:0
Ok you need a pc and usb cable to connect your pc to your jbl tuner.
  1. Connect your jbl tuner to your pc.
  2. Press and hold [DAB/FM] and [Volume -] buttons simultaneously for >10 seconds, until you see message on display “connect to PC then copy updated File”
  3. At your PC find your USB Drive and press eject.
  4. Your jbl tuner 2 will reset and turn on again in 10 seconds.
crwdns2889612:0crwdne2889612:0 10
I tried this procedure on my acer chromebook. All went well until I clicked in the wrong place. Now my jbl tuner dab/fm is frozen," No update file" is on the display. Now it won't power off .
Thank you! That's was Ok!
Perfect solution!
Yes worked for me
oh great, that worked. I thought I had blown up the JBL Tuner 2 by connecting it to a fast charger, after which I only saw the power indicator but it would not turn on anymore. But this solved it. I used a Mac instead of PC, so that makes no difference. Thanks!!
I followed next link: https://files.zutphen.nu/JBL-Tuner-Hacks...
and had succes with pressing DAB-FM & BT at same time for force power off
Thanks Isoete,
No way to switch it on. Just pressing both DAB-FM and BT buttons actually solved the problem.
Thanks, DAB FM And BT buttons resolved issue for me too.
doesn't work. EXIT DFU MODE and than this "normal" text : Connect with PC or MAC than copy update File
Thanks for your help! I had the same problem. Just connecting it to my laptop and then ejecting the usb drive did the trick. Thank you so much!
Witam mam problem z jbl tuner2 nie mogę przywrócić ustawienia fabrycznych przy pierwszym uruchomieniu przez pomyłkę ustawiłem język wydaje mi się że to Holenderski i nie mogę go zmienić.
you can refer to this manual: https://www.manua.ls/jbl/tuner-2/manual
I don't have a DAB FM button. What is this?
Sylvana check this picture for reference: https://manuals.plus/wp-content/uploads/....
If you only see an FM button though, then you actually have a JBL Tuner (v1), which doesn't support DAB (Digital Audio Broadcasting). The reset procedure is a little different, once the device is switched on, you have to press Volume Up and Bluetooth button combination and hold it for 10-20 seconds, as described here: https://www.hardreset.info/devices/jbl/j...
Great help, it worked.
though it was challenge to navigate my 77 years old mother over facetime to do this technical stuff on PC. Wrong usb cable, then she pulled out mouse cable by mistake and so on :-)
Anyway thanks.
If I connect the box to my PC, I don't see any message or USB file popping up in Files. What do I do?
Mohammad Fairus Khalid crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 182
crwdns2942667:0crwdne2942667:0 31,099
