Repair guides and disassembly information for Apple's 8th generation iPad. Released September 18, 2020. Model numbers: A2270, A2428, A2429, and A2430.
crwdns2934591:039crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Charging only on low wattage charges, and only for a few minutes
This ipad is charging only on low wattage chargers and only for a few minutes before it displays “ipad not charging.” A new battery has already been tried, as well as several resets and updates. I'm not 100% convinced that this is a charhing pirt issue but I dont even know anymore, any suggestions?
crwdns2942205:01crwdne2942205:0:
Did you even try changing the charging cable?
I feel it's not original cable that you are using to charge your iPad.
it could be the wall wort or cable is damaged and I hope that is the case. if ot those than the port probably needs to be replaced or you can a bad resistor on the charging circuit.
Garrett Chism crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 86
