Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Draining the battery on an ipad mini A1432
So i’m doing this iPad mini screen repair. I’ve used the CPB Heating mat to lose the adhesive tape so i can pry it open. The heating mat works wonders, it opens with less mess. I always test after opening the damaged screen to see if the iPad still works. The device works but since that screen is cracked really really bad, the touch screen doesn’t work at all. My question is, how long that the battery will last since I want that thing completely dies so i can safely disconnect and reconnect the ribbon cables. Please assist, thanks!
I was able to do the work without any further issues, kudos for your assistance!
It would be quicker and safer to disconnect the battery. You will have to remove the plate anyway to disconnect the screen flex, and the battery connector is right beside it.
Oh okay, I can still disconnect the battery regardless if the iPad is still on.
@uitadmin Yes it is perfectly safe to do so.
Gabriel Rodriguez crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 129
