What is the middle battery connector for?
After Ipod touch battery replacement the battery has been getting stuck at 19% or less
then when it gets low enough the ipod shuts off,
and it take a while to get it to start up again with it plugged in,
Is it possible i got a defective battery?
crwdns2944067:014crwdne2944067:0
@beanman56 it's possible. where did you get it from?
I got my battery from ifixit,
so whats the middle connector for?
@beanman56 On the 6 gen I am pretty sure the centre pin is the battery data.
Is it needed?
Cus it was ripped off the board
@beanman56 Usually one or more pads come off when this happens. How’s you’re soldering skills?
crwdns2934275:09crwdne2934275:0
Hi
Hope you are well
I did not know really know how to explain this but I had a 6th gen that had the middle battery connection ripped off from previous repair and I noticed that mine would get stuck at 17% and when it would die it straight up wouldn’t charge again but there are test pads above the 3 battery pads and I found the one in the photo had a connection so I ran a jumper and it started working again so hopefully my complex explanation as helped
Anymore questions please ask
crwdns2944067:010crwdne2944067:0:
Whats a jumper
@beanman56 A jumper is copper wire that you use when a trace or pad is broken between components. The average size wire is 0.01mm
@hellomacos - Ok i see
@hellomacos - What size should said jumper be?
@beanman56 where you been Sir? Doing ok?
crwdns2934275:05crwdne2934275:0
Ben Capehart crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 577
