4 fridges - none working! Could it be electrical?
This has been an ongoing 4+ month process, so I’ll try my best to condense the story. I’m a renter. 1st fridge was 30 years old. Totally stopped freezing/cooling. Replaced with secondhand fridge that was known to be working. Seemed to work, except 1-2 times a day it’d heat up above 40F and stuff in the freezer would melt. Then over about 4 hours, it’d re-freeze. Often the fridge would also heat up and get up to 55F or even more. Landlord replaced defrost timer, bimetal, thermostat. Seemed to help a little, but still the same problem…
So he ordered a new fridge. New fridge comes and seems okay at first, then the same problem. I started keeping an eye on it and realized I think the problem is during defrost or times it’s “off”, the fridge not only heats up too high, but takes way too long to cool down again to safe temps, which was causing the food to spoil. Sometimes it stays off for a long time and won’t turn back on.
A repairman came and he thought the new fridge had low refrigerant or a blocked line which was causing the compressor to overheat and malfunction. I noticed sometimes when it shuts off, it will repeatedly go “click…. click…. click” like it’s struggling to function. So he said yep, could be. We got a brand new fridge again as replacement. SAME PROBLEM.
Now this new fridge has the problem above. It also will randomly start spewing out snow into the fridge on the back wall from the upper vent. Changing the settings does nothing really. If I keep the freezer at Max, it will hold the freezer temp at 0F for a lot of the time, but at least several times a day it spends extended periods of time at around 14F… And then as mentioned, rises up above freezing and takes hours to get to 0F during which things defrost. Maybe 1 day a week it will stay fine all day. It’s not totally consistent which seems weird to me. The fridge is still all over the place too.
Could this be a problem with the electrical in the home? It’s a 1930s house, not sure how/when things were updated. Sometimes lights go brighter, sometimes dimmer. Certain items short out. We don’t have a dryer and our oven is gas, so I think maybe a problem was hiding and the fridge just brought it out. My worry would be Loose Neutrals, but I know there are other less dangerous, more likely problems.
Any ideas? My landlord is resistant to getting an electrician out and I think he may think I’m crazy, but the chances of 4 fridges not working seems ridiculous to me. I have 3 separate thermometers, one is a stick in liquid, one shows range, and one is just a standard restaurant grade metal thermometer.
I am pretty frustrated by now. I have thrown out and replaced probably $1,000 of food over the past several months and I ended up having to take out a line of credit to try to catch up financially. I just need a working fridge! Any advice is very, very welcome. Especially anything I can tell my landlord to convince him to at least let me have an electrician look at it as they need his permission.
crwdns2942205:01crwdne2942205:0
hi - I am having the same problem. Thought old fridge was bad and one 3rd new fridge. Temps keep fluctuating up to 56/60 and back down. Did you determine your issue? Was it electrical outlet?
crwdns2934271:0crwdnd2934271:0 T Tomp crwdne2934271:0
