Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Scratched off some of the black paint covering the wireless charger
Whilst trying to remove the battery to change it, had to use some fairly brute spudger action to separate battery from Apple’s seriously ridiculous double sided tape. Unfortunately in the process, I scratched off a fair bit of the black paint over the wireless charge. Is this bound to cause any issues?
It should still work fine as long as you did not cut through the copper coil! if you scratch the paint it is fine to operate normally
no issues as far as I see it if you nick the coil it may break it so the power will not go through the coil, therefore, making the phone unable to use wireless charging other than that being AN issue it should be just fine with the paint scratched
If the entire black scratches off and the coil are exposes what would be happen
@mariacrist95460 Probably nothing; the coil sits immediately underneath the battery, which has a protective, non-conductive liner covering it, so as long as you don't add any kind of adhesive to the coil itself (the stock adhesive avoids the coil intentionally), there's no reason for concern.
Trance Dude crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,176
