The Jabra Speak 710 is a Bluetooth and USB speakerphone for conference calls.
How to open Jabra Speak 710?
Answer:
On 710 you open from the top.
Remove carefully the metal piece over the speaker with your nail or a thin plastic spudge and carefully press it upp until it's removed.
Remove the 4 T6 screws on the speaker.
Now the bottom is removable and you can access the 8 T8 screws (similar to the 510).
This is just to mark it as accepted.
“On 710 you open from the top.
Now the bottom is removable and you can access the 8 T8 screws (similar to the 510).”
Thanks All - I had a brand new still in the Box one before full Jabra branding. Its an OpenCodecs and I couldn't get into it - I was determined it was a case of getting the base off to get at the 8 screws underneath. In classic me style I bought this in clearance from a wholesalers here in NZ and put it on a shelf to forget about it for years and the batteries are at 0.5V so not charging.
I didn't actually realise it was rechargable when I got it - Thought it was permanently USB tethered.
I'll see if I can tickle the batteries up to charge or replace them and it'll probably remain sitting on my desk for inhouse use now.
Got the replacement batteries from Aliexpress this-morning - Solidered them in and the speakerphone is working like a dream USB with a PC or Bluetooth on Battery! I got a pair of these. I've literally just fitted them and they came pre-charged so the only thing I haven't confirmed is that the batteries charge.
https://www.aliexpress.com/item/32883028...
Musse crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 677
