Repair and additional information for the Amana ASD2522WR*0* refrigerator, a side-by-side model with an ice dispenser, introduced in 2008 by Whirlpool Corporation. This page covers information for model numbers matching the pattern ASD2522WR*0*.
Freezer intermittently melts ice then refreezes
My 12 year old Amana ASD2522WRB03 side by side freezer has an intermittent issue where the ice melts then freezes again into a “block”. This was happening every few months, but is now happening more often-every few days. I assume the defrost cycle is staying on too long or coming on too often. The coils under the unit are free of dust/debris, the compressor and fan both are running. The door seals are all tight. Inside the freezer, the evaporator fan runs, the evaporator is not frozen up, the heater seems to work when in the defrost cycle. A friend suggested the defrost timer, but my unit does not have this “mechanical” device. I replaced the electronic defrost control board, but it did not fix the issue. I was going to try the defrost bimetal, but could that be intermittently faulty or is it the type of component that would not work at all?
Hi,
Here’s the tech sheet for the refrigerator. This shows how to test the bi-metal thermostat.
Being a mechanical switch it is possible that it can be intermittent in its operation. It comprises of two dissimilar metal strips that react to temperature. Either moving away from each other or towards each other depending on the temperature, to either complete or open an electrical circuit. This should happen at a known set rate but age can affect it.
If the tests indicate that it is faulty then here is a link that shows where it is located in your refrigerator, how to replace it and how much it may cost.
There are other suppliers online that may suit you better. Just search for ASD2522WRB03 parts to get results.
Sandi Barbknecht crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,216
