How can I partition my hard drive?
I have a 800Mhz, 256MB Mac OS 10.4.11 iBook G4. I want to split my 30GB hard drive in two, a 27GB block and a 3GB block. How can I do this? Do I use Disk Utility or is there some freeware that partitions hard drives?
Once I have the 3GB section I plan to restore it with Ubuntu 6.10, I have tried the install function within the Ubuntu OS but I get stuck at step 5/6, it asks me where I want my mount points for "/" and "swap" to be but no matter what I select, I cannot progress to step 6/6.
If anyone has a solution within Ubuntu I will try those first, then partitioning outside of Ubuntu.
I think you need to have a partition just for swap, as well as for your root directory.
My other answer is incorrect because Boot Camp is 10.5. I guess I would use a Copy of Carbon Copy Cloner and clone my Drive to a firewire drive, then use the Disk Utility to partition the Drive and Clone it back onto my Laptop..
I would use Boot Camp to Partition Your Hard Drive...If your using 10.4 it should be in the Utilities folder that resides in your Application Folder.. As a suggestion.. I would update your 30 GB drive to something a bit more substantial.
3GB may be too small for the OS and VMEM/Swapp files (I know there's minimums for certain OS's but can't remember what they are off hand, a search would trun them up)- could you split that a bit larger?
N.
The minimum is 2.25GB
My experience with Ubuntu is that it requires more than 3GB of hard drive and it also needs a swap drive. You can use the Disc Utility to partition, but this will wipe what is on the hard drive. Boot camp might be used without loss of data.
QEII Student IT crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 3,979
