No Sound on GBA SP AGS 001
No sound at all. Used a spare known working speaker from another AGS-001. also tested speaker that was in Broken SP, it works.
Tried Cleaning Volume Slider with alcohol. Nothing.
Tried using Headset jack (converter piece) no sound on there either.
Re-soldered the speaker contact pads on the motherboard of SP, Still no sound. Not sure what else it could be.
Cleaned Thoroughly with ISP alcohol, still nothing.
GBA Games work otherwise perfectly fine. could it be a capacitor or a fuse?
I'd also like to add that I made sure that pins on speaker were making contact with the Motherboard by putting some electrical tape underneath pins. Like i said, both speakers worked on the working SP. so its definitely Contacting pins on the Motherboard.
