jack polarity on Xoom tablet
The wall wart on my xoom tablet has died...not enough output to even test polarity. Does anyone know for sure what the center and sleeve polarity is? I want to adapt another 12v charger.
The tip is positive and the sleeve is negative. Sleeve being the outside and tip being the inside. The original charger is 12V 18 W 1500mA from what I read. Hope this helps, good luck
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 2,049
OK, the problem was with the cable from the charger to the jack. The jack is molded inline on the end of the cable. When it is plugged into the tablet and the tablet is resting on a lap and the cable routes to the side. The wires can not accommodate any sharp bending at the jack. When I cut the cable from the charger and chased the continuity the wires were shorted going into the jack molding. I was able to remove enough of the jack molding to re-attach the wires. I made up a right angle connection to the jack with RTV molding so the wires won't see a sharp bend. The charger seems to have put up with the situation and outputs 12.06v. So I guess all I can say is be careful not to kink the cable.
crwdns2934271:0crwdnd2934271:0 Carl Martin crwdne2934271:0
