TV backlight powers on when plugged in, but unresponsive
LCD screen (backlights I guess) immediately turn on when the TV is plugged into the wall, but there is picture or response from power button. This particular TV was a casualty of a severe thunderstorm.
I’ve checked the power board and the main control board - neither seems to have heat damage. The fuse shows 0 ohms on my DMM, so I think it’s still good. Tried with another fuse anyway. Disc Capacitor in EY25 & EY26 heats up quickly. I don’t see anything else unusual with other components on the power board. I’ve unplugged the cable to the main board, but problem persists.
Before I try replacing the boards, does anyone have any suggestions?
Hi @jeffthewhiteguy ,
What is the model number of the TV?
Was the TV on at the time of the storm? You may be unlucky in that both the mainboard and the power board have been damaged.
The screen backlights turning on when the power is connected to the TV is not a good sign.
Normally with Samsung TVs (and most others) when the power is first connected the TV’s LED Standby power light turns on and that is all.
A quick backlight test with some Samsung TVs to make sure that they’re working OK and that the power board is working to some degree (enough to power the backlights anyway) is to disconnect the mainboard - power board cable from the power board and connect the power. The backlights should turn on because the signal from the mainboard that stops this from happening when power is first connected is missing i.e. cable disconnected.
Secondly with all boards connected and the power is connected to the TV, the Standby light is turned on by the mainboard when it receives the Standby voltage signal from the power board, indicating that power is available. When the TV is turned on by the remote (or the TV power button), the mainboard commences switch on by sending a signal to turn the power board full on so that all the necessary power is then available.
You need to check if the PS_On voltage signal is there all the time on the power board when it shouldn’t be when the TV is in Standby mode or if the Standby voltage signal (STBY) is there. The STBY voltage value is marked on the power board somewhere - either near the cable connector for the mainboard cable or perhaps a link on the board itself.
Knowing the power board model number (possibly BN44-??????? - or the TV model model number to find the power board) will help to hopefully find the schematic for the power board so that more detailed diagnostic testing can be done. Mainboard schematics aren’t generally available or not that I’ve found anyway.
Thanks for your response @jayjeff!
The model number is un55eh6000fxza and the power board I believe is BN44-00499A. I have already tried disconnecting the main board and powering on - backlights come on same as before. I believe my next step is to test the standby power, but I'm not sure where it is on this board.
I have located the STBY voltage on my other TV power board (that will be a separate question) but I cannot find it on this one.
@jeffthewhiteguy
Looking at this image of the board (hover your mouse over image to zoom in) I can't see it either, but check what the PS-On/Off voltage is on CNM803 pin 14 (bottom left corner of image).
Also check the 13V and 5V supplies values on the same connector.
With the mainboard cable connected it will be difficult but with it disconnected the power board should be turned on as you have the backlights so the signal is missing on PS_On/Off coming FROM the mainboard.
You may have to remove the power board and follow the tracks to where CNM 803 pin 14 goes to that will allow you to connect your meter more easily so that when you reconnect the mainboard cable to the power board so you can measure what the PS_On/Off voltage is with the mainboard connected but the TV not turned on. if it is the same then there is a problem in the power board.
I can't find a schematic for the board so proving which component is faulty will be difficult.
@jayeff I'm a total novice when it comes to checking voltages, but I tried my best to check the connector from the power board to the main board. Assuming that pin 1 is the top left, pin 2 is bottom left, and so on... I got the following voltages:
1) 13.03 2) 3.45
3) 13.03 4) 13.04
5) 13.04 6) 3.00
7) 13.03 8) 0.00
9) 0.00 10) 0.00
11) 5.36 12) 5.36
13) 5.36 14) 3.35
Voltage across the fuse was 0.05v .
I tested the board completely disconnected. I couldn't follow pin 14 on the bottom of the board, but I will try again if necessary.
@jeffthewhiteguy
You counted them correctly. Pin 1 is numbered and designated on the board with an arrowhead so it is the top left. Pin 13 is also numbered but no arrowhead All the odd numbers are along the top row and all the even numbers are on the bottom row as shown in the pinout table printed on the board near the connector.
You can easily measure the odd numbered pins with the cable inserted but not the even numbers (as long as you don't short out the pins with the meter's test probe ;-)
The 13V and 5V voltages seem to be about right, it is the value of the pin14 PS_On/Off that would be of most interest.
I'm assuming that these measurements are with the cable disconnected so it would be good to find a suitable measuring point that connects to pin 14 so that you can measure it with the cable connected to see if it changes at all. That's where having the schematic would have come in handy ;-(
My thinking is that usually the backlights come on when the cable is disconnected so there must be a control voltage coming from the mainboard to keep them off until the TV is turned on with the cable connected, because when the cable is not there they turn on i.e. no voltage.
Given that the Standby voltage is the only voltage available to the mainboard in Standby (and this is what I don't know for your model it could be either 5V or 7V as it is in other Samsung models) a control voltage of no more than either of these voltages should be there. It could also be less than those mentioned but not 0V as then the backlights should turn on as they do when the cable is not there. Hopefully you follow my reasoning.
You could always contact the supplier in the link I posted above and ask which board is the more likely problem. The worst they could do is not tell you.
Jeff crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,961
