A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
How to change the front glass only.
How do I change just the front glass screen? Any help
I have not done this myself.
https://www.youtube.com/watch?v=H6ZM_arR...
Just a further note of caution on this;
When cutting through the adhesive holding the glass it is REALLY IMPORTANT to only insert the tool up to approx 6mm under the edge of the glass. Sliding it in further can damage the digitizer.
At the long edges the adhesive under the glass is only approx 2-3mm from the edge. On the short edges it is wider, maybe 5-6mm from the edge. Once the adhesive is hot it is quite easy to cut with a plastic guitar pick but do not slide it in too far. I used a little alcohol on a cotton bud to lubricate the guitar pick and help it slide.
Once the glass is off, the access to the remaining parts is quite straightforward.
You will need to source a replacement adhesive strip which can be found on internet sellers.
Katie Hopkinson crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 192
