The Ford Fiesta is a subcompact car (B-segment in Europe) manufactured by the Ford Motor Company since 1976.
crwdns2934591:023crwdne2934591:0 crwdns2934593:0crwdne2934593:0
My lock fob has suddenly stopped working on my Ford Fiesta 2012 plate
My key fob has stopped working on my fiesta. I can use the key to manually lock and unlock the doors.
can’t change battery as it’s a sealed unit
Update (09/02/2021)
her is a picture of my fob
Hi @joys2121 ,
Here’s a video that shows how to open your key fob to replace the battery.
The battery model used is a CR2032. It is a common battery available most everywhere e.g. supermarkets.
Note: Ensure that you insert the new battery the same way as the original. There is a +ve symbol marked on the battery so that you know which way it goes into the battery holder.
crwdns2942205:01crwdne2942205:0:
Thank you so much for your help changed battery easily with the help of you tube had to re program after changing the battery but google helped with that
Hi @joyspurrier, can you attach a photo of the key fob? (Click here for directions on how to add photos to your post.)
Even with the “sealed” devices you can usually get into them with a spudger (or a guitar pick, credit card, or flat head screwdriver). Once you’re in, you should be able to swap out the battery. This guide has a quick video example of using the key to open their fob.
Hope this helps!
crwdns2886500:0iFixitcrwdne2886500:0
crwdns2930805:0crwdne2930805:0
Adding images to an existing question
crwdns2934079:0crwdne2934079:0
crwdns2937585:0crwdne2937585:0
2 - 5 minutes
crwdns2886500:02009-2015 Toyota Prius Key Fob Batterycrwdne2886500:0
2009-2015 Toyota Prius Key Fob Battery Replacement
2 minutes
joy s crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,032
