Battery light flickering on dash
Battery light flickering on dash what's the problem
It sounds like you are starting to have alternator problems. From my experience, the light only flashes if the alternator does not produce any charge. Whenever the brushes on the inside of the alternator are starting to go, or the voltage regulator is starting to fail, the charge light will start flickering/flashing in a somewhat regular pattern. If the light is flickering in a very irregular pattern, check the fuses, belts, all wires and connectors for corrosion, and the dash bulb itself. I would suggest that you check your alternator output. Autozone comes to mind, since they are doing a lot of free checking and have most of the replacement parts.
I WILL CHECK THE CONNECTORS
It started showing the b-light on my way to work. it comes and go. but when i remove terminal from the battery car goes off. so i guess is the alternator need to be replaced.
crwdns2942667:0crwdne2942667:0 18,985
Replaced my alternator and battery today. Now the battery light flickers. I've replaced the parts so what could cause this?
crwdns2934271:0crwdnd2934271:0 Emilee Smith crwdne2934271:0
