Hi @Jeremy Erickson
What you did was a power refresh.
By disconnecting the power from the TV and then operating the TV's Power button for about 60 seconds you are forcing the TV to try and turn on. Of course it can't do this because there is no power.
What does happen is that any residual power that it still in the TV is dissipated by doing this and this resets any data that may have been corrupted due to power fluctuations etc which may prevent normal operation back to its factory default condition.
It’s a standard first option to try with most electronics these days, TV’s, computers, mobile phones etc. The hard part with phones and laptop computers is that the power source i.e. batteries, are no longer as easily accessible as they once were.
it may be prudent to disconnect the TV from the power if leaving it unused for a length of time as you may not know of any power problems i.e. surges, outages etc that might have occurred, unless you have a clock radio that will flash indicating the power has been interrupted but if it has a backup battery then even then you mightn’t know.
Connecting the power to the TV via a quality surge protector might also be a good move.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
Hi,
Was the TV still connected to the power whilst you were away?
Does it do this if you disconnect the HDMI and just view the TV menu screens?
Also check if it has the latest firmware installed
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
TV was connected and had just had an update prior to leaving.
I did try with no HDMI connected and it had the same issue.
One thing I did try last night (that I found as a suggestion for a different LG) was to unplug my TV, and push the physical power button 50+ times (I pushed it 60). This has appeared to work for now, although I have no idea why.
crwdns2934271:0crwdnd2934271:0 Jeremy Erickson crwdne2934271:0
My LG smart TV all of a sudden last night decided to start turning itself off and restarts. I unpluged it, put it in an outlet, took off any timer settings when it would stay on long enough to do that, but still will freeze and shut off within a few minutes then restart. What else can I do?
crwdns2934271:0crwdnd2934271:0 Janis56 crwdne2934271:0
