The Chevrolet Silverado, and its mechanically identical cousin, the GMC Sierra, is a series of full-size and heavy-duty pickup trucks manufactured by General Motors and introduced in 1999 as the successor to the long-running Chevrolet C/K line. The Silverado name was taken from a trim level previously used on the C/K pickup truck from 1975 through 1998.
My cruise control only works when it wants
My 2011 Silverado 1500. The cruise control only works when it wants to. I press the cruise button and nothing happens; after a while or another day it works for a while
From what I'm finding, a common fix that has worked for many and is cheap has been to replace the brake lamp switch. Its like $20. If that doesn't do it it might be an issue with the switch/buttons itself and you might have to replace that. Next time it doesn't work try tapping the brakes a bit and trying again. If it starts working then replace the brake switch.
The cruise module is down behind the brake pedal U can replace it Or if it doesn’t work when u press it Just give it a little kick and it will work.
Enrique Mares crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 968
