Personal computer produced by Toshiba in early 2014 . The Satellite S55T-B5335 has a 15.6" touchscreen display, Intel Core i5 processor, and 1 TB hard drive.
What screws does this use?
I lost all of the screws of this laptop after taking it apart, does anyone know what kind of screws it uses so I could get new ones? Thank you very much
I dont know how you lost the screws all, but anyway in Toshiba Laptop before they have Type of screw in each hole of the laptop F8 is a common screws of them outside the case, inside screws like mounting the Motherboard are short 3mm to 4mm, it depends you have to be very carefull when choosing the right screws as it may damage the board if you wrongly use long screw, you can buy in Amazon the universal screws just make sure to gauge the length you need before forcing a long screw that will hit your motherboard. I hope this helps you out. Good luck.
here is the link
https://www.amazon.sa/-/en/Anself-300Pcs...
Thank you very much, will do
Daniel Cunha crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 434
