The Asus K55A can be identified by its model number SI50301P. The laptop was released in February of 2012 and is powered by a 3rd generation Intel Processor. This laptop fits into the mid tier of value computing for its release year
Computer not booting up
Laptop does not boot up half of the time, when it does it freezes or displays this.
Note I have Ubuntu installed.
I think i need to reflow the solder.
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
@sunflowerthomas
Try booting the laptop using a standalone program (loaded onto a bootable USB drive) that doesn't require an OS to run.
If the laptop boots OK consistently and the program works then the problem is with the OS or the HDD.
I know that the program I linked is a memory test program and I don't think that there is a problem with the memory, (although i suppose there might be?). It's just that this program doesn't need an OS or HDD and also it tests a lot of other parts of the motherboard just by it working OK
I might reflow the solder on the motherboard.
@sunflowerthomas
I think that's rather drastic unless you've tried everything else e.g. check / replace ram try new HDD reload OS etc as you could lose the motherboard if you get it wrong. Just my view
@sunflowerthomas
Yes very drastic.
Is it stable if you just boot to the BIOS/UEFI ?
Remove power, via cable and battery pack. Press on button for several seconds. Reattach power, should boot after 10 seconds.
Thomas Rogers crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 488
