Why is my screen color looking like a negative picture I had a normal
Please help me get my phone screen and picture back to normal.
Try Settings>Accessibility>Set Color inversion to off.
, well I tried that it didn't help my phone still looks like it has a negative I don't know how to fix it
Hi @Lynda Garcia
If you have a Moto G power (2021), try starting the phone in safe mode and check if that resolves the problem.
If so follow the instructions in the link to find the cause.
Try turning negative color mode on then off.
I went into accessibility and kept on inversion color it might be another name on your cell phone but it has to do with color and then you can tap a couple of different buttons that you see and try them and it brings the screen back to normal my cell phone was like that for 2 days
Check the display screen connectors. Make sure they're connected completely and correctly. I would remove them, make sure there is no dust or lint and reconnect.
my phone galaxies12 does not have any colors in his pictures
that did not help
If the broken display is still available, disconnect the new one, reconnect the old one. If the display shows as it should, the new display is faulty. Send it back with an explanation and get a new one. If the display does NOT show as it should, it's possible something was damaged on the board during the repair. You can use a camera's zoom to check.
Its not a problem its a feature of your smartphone it is made for those people who like to read books in their smartphone.
To fix this issue you just have to disable it from the settings and after it you are done.
https://okadtech.com/moto-g-screen-color...
This article will help you to disable this feature.
I am not wanting to. Disable my phone then who will fix that?
By doing this you WILL NOT disable your phone. You will just shut off the "invert colors" mode.
My phone looks like a negative how can I fix this
@shiela markley What have you tried doing to fix it? Did you try the suggestions in this thread? Are you also talking about a Motorola's Moto G Power 2021?
What happens when that don't work it did in safe mode in galaxy a03
My screen is in negative mode, n
How do I get it back to normal
Hi @ro3471,
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 187
crwdns2942667:0crwdne2942667:0 9,101
