Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Adhesive Strips Numbers 11-16
I try to keep adhesive strips in stock for both the 21.5” and the 27” iMacs. I noticed the the parts are now using higher numbered strips than what I am installing. Does anyone know why the number change? These are definitely for the 27” models. Are they just old stock or were they replaced by better strips?
iMac Intel 27" (2012-2019) Adhesive Strips
iMac Intel 27" Retina 5K Display Adhesive Strip Replacement
crwdns2886500:0These replacement foam adhesive strips secure the display compatible with the A1419 model 2012, 2013, 2014, 2015, 2017, and 2019 27 inch iMac and the A1862 iMac Pro.  EMC 2546, 2639, 2806, 2834, 3070, 3194, 3144.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$29.99
I go by the part numbers as an example the original 2012 ~ 2015 27” models have the following: 076-1419, 076-1444, 076-1416, 946-4547, 946-4548, 946-4549, 946-4551, 946-4550 & 946-4552 for their tapes
The 2016 ~ 2019 models use this set: 076-00332, 076-00330, 946-4552, 946-03774, 946-01031, 946-03775, 946-07462 & 946-07463
The real difference is the holes for the microphone. You can use either tape set as long as the holes needed for the microphone is in the correct location.
mayer crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 394
