Phone stops charging halfway.
After my phone updated to Android 11, it stopped charging at halfway or so, depending on what battery percentage I charged it on. I had to re-plug in the cord before it starts charging again. I have tried to charge it while the power is off, it works that way but it is bothersome for me. I don't know if it is from the update or it was really the phone's problem. What do I do?
have you checked your battery health settings it may be set to stop charging automatically halfway in order to increase the battery's lifespan and health
you should try rolling back your phone to the previous version and seeing if that fixes it that way we can narrow down whether this is software or hardware
@rektronik Hi. where can I find the option? I can't find it on mine but I found a "tip" that says:
About continuous charging
Continuous charging over long periods can slightly reduce battery life.
Check to see if the charging point is dirty or contaminated. Often dust lint and debris enter the port at the bottom of your phone while stuck in a pocket or purse! Carefully using a hooked plastic or non abrasive material into the port and carefully dislodge the offending debris! You'll often find the charger fits better and stays in place without jigging it to get it into the port. This should be done every 6 months at minimum!
