Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
How to replace Home button flex cable
Does anyone know how to repair the flex cable for the home button. One of the spring-loaded contacts broke which I fixed with a spot of solder and a small metal prong. However I am banking it won't last forever so would like to replace the flex cable at some point.
The bit I need to replace is this
http://www.digiexpress.us/iPhone-3G-Home...
I am guessing I'll need to get the plastic button out then insert this through the hole in the top case, but how does the home button pop out?
crwdns2889612:0crwdne2889612:0 -1
The home button is held in by the glass digitizer - there are tabs on the left and right sides of the button.
This picture has a pretty good view:
http://s1.guide-images.ifixit.com/igi/RI...
So, if you need to replace the home button itself, you are going to have to remove the digitizer, and will need these to adhere it back in place:
http://www.ifixit.com/iPhone-Parts/iPhon...
solarisjon crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 12,638
