Guides and handbooks for repairing your Melitta Cl Touch.
Coffee is not brewing, water going straight into drip tray
My coffee machine has developed a fault whereby it will not make a coffee. When I press a button to start a brewing cycle it grinds the beans then sounds as though it is working but no coffee comes out, the water goes directly into the drip tray and it dumps the ground coffee straight into the container within the drip tray (the coffee grounds are not 'tamped' down, just loose grounds).
Any advice on how to fix this issue would be much appreciated
The problem most likely is in the ceramic valve that chooses where the water must go, it has a plastic gear that snaps very easily , the replacement costs around 10$ and is fairly easy to change.
Stephen Mooney crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 434
