The coin lock cap broke off and stripped
The coin operated battery lock cap broke off on my MacBook and the lock itself is stripped.what should i do? The battery doesnt lock now so i have to tape it to the case..plz help
Can you post a picture of how exactly it's broken?
If the switch is stripped and can't be operated with a coin anymore, you can try using superglue (to attach a coin or something else to grab onto) and get enough leverage to twist it back into the locked position.
The battery lock mechanism is part of the MacBook bottom case and it can't be swapped. You need to replace the bottom case. Try to find a used bottom case in good condition.
http://www.blogcdn.com/www.joystiq.com/m...
Hi
I've got a similar problem except the lock pinged off whilst in the locked position so I can't actually take the battery out!! To add insult to injury, this only happened when I was about to replace the battery which no longer charges!
Is there a way of removing the bottom case without taking the battery out?
sanane crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,244
