master cylinder slave cylinder
i have a dodge 3000GT stealth, is a 1993 model but the engine is from mitsubishi. i had a problem about 2 months ago with the slave cylinder and i think i mess up the clutch which it got replace, well now i have to put clutch fluid more often than usual, i check the interior or the car where the clutch pedal is and it looks like is leaking oil from the inside and not from the outside. I am thinking that it might be the master cylinder. i want to make sure that is the right part that i need to replace so i don't make any mistakes. any suggestions?? or advices??
