Samsung TV permanent vertical lines
I have the same problem, mine started this way Samsung TV permanent vertical lines
Last week the screen went completely blank with a gray/black screen. I did light test no image, and I do have backlights on that will lit up once I disconnect main board from power board and sounds works with no problem.
Any suggestions on what to check or replace ? Is my tcon board integrated with my main board ?
If any one could share some wisdom and knowledge I would really appreciate it.
@jayeff the model number is UN65NU6070FXZA
Hi @vraptor
Check where the flat ribbon cables that go to the screen come from.
If the main board has a cable that goes to another board (not the power board) which then has 2 (or more) cables going to the screen then that board is the tcon board.
If the mainboard connects to the screen (2 or more cables) then the tcon is inbuilt with the mainboard.
The tcon is integrated with the mainboard
If you haven't already replaced the mainboard that would be the first thing to do.
If no good then it may be the driver board that the mainboard connects to but you can't replace them that easily as the cables from them are attached to the screen and are very fragile.
Vertical lines can be a processing issue or a connection issue. Usually, these are due to poor connections between the processing board and the panel. If you feel confident enough, remove the back of the assembly, then remove and reinsert the ribbon cables to access the panel. This will often solve the problem. Be careful as these cables are delicate and can be easily damaged. The connectors should have "locking tabs" which also need to be released to get the cables out. If this reinstallation does not resolve the problem, further investigation is necessary and should be performed by an experienced repair shop.
I have a SAMSUNG 46” TV MODEL# LN46C630 manufactured
April 2010. Has a really crisp picture, so I don't want to replace it. The vertical color lines started appearing and a light smack on the back of TV would clear it up for a short while. I thought It must be a loose connection.After removing the back cover all cables were connected solid. No evidences of burned out computer boards parts. I did notice the LCD screen was very hot. Solution; put a small fan on uncovered back of unit. That was three days ago and I have had no more vertical line problems.
Replace cover and place fan blowing on lower air vent holes. LCD Screen is running much cooler and no vertical lines have appeared in five days. Hope this solution for my TV will help someone else. Bill H.
A Valencia crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 212
crwdns2942667:0crwdne2942667:0 8,143
