Can I change the processor?
How do I change the processor?
Hi,
You can try changing the CPU to improve performance but it won’t improve it that much.
The laptop only supports a maximum of 4GB PC3-8500 200 pin SODIMM ram and even though Win 10 will work with this amount of ram it works a lot better with 8GB.
The CPU is a Socket-P µFCPGA type but you may have to check what chipset is used to make sure that you get a compatible CPU if you decide to upgrade.
It may be easier to try replacing the HDD with a 2.5” sata SSD and then check the performance of the laptop. (check online for how to replace a laptop HDD with a SSD)
Here’s a link to the service manual for a PB DT85 laptop that may help. I think that it is similar to your model.
Go to p.73 to view the necessary pre-requisite steps and then the procedure to replace the CPU.
crwdns2942667:0crwdne2942667:0 628
