The volume output is very low
I have a Yamaha DGX-220 and the volume output is very low. Can I fix that, or must I refer ta specialist?
Hi,
As @ruggb suggests this requires testing the circuit as the audio outputs are supplied by a single audio amplifier IC, which may be the problem
It could also be the master volume potentiometer VR551 that is the problem though.
Here’s the service manual for the keyboard.
Go to p.8 to see the block diagram and find the Power amp IC551 and next to it is the master volume control VR551. This is just to give context as to how the audio is supplied to the speakers. There is no detailed wiring schematic for the board, only a board layout so this will have to be worked out if wanting to test the volume control.
On p.29 and p.30 Test #13 it shows what equipment is needed to test the volume and what audio levels are expected.
You may have to contact a reputable, professional electronics repair service (perhaps specializing in electronic piano or keyboard may be best) and ask for a quote.
Hi, I'm a technician, also have dgx 220, I don't think it's the circuit or ic, because the sound is not distorted in any way, or the potentiomer for its not intermittent, its functioning good. It just not the sound level as other model of yamaha. I just want to know if there's a setting or function that is not right. Or the sound level is its normal design. I can boost it up by adding an op amp circuit, I have use it in my other keyboard that has a defective op amp ic, I think it will work, I just need to know if it its normal design to have low volume.
I have resolved the issue. I replaced 4 resistors in the amplifier stage, located at the input ic of the amp. 2pc, 4.7k ohm, located at the front of the ic, replaced by 100 ohm, and 2pc 10k ohm located near the ribbon wire, replaced by 1k ohm. I have notice some difference in diagram design that I've search from the Web to actual design in the keyboard.
I think yamaha replace the original design board with other model board. So it doesn't match the input resistors from the mother board to the amplifier board.
There’s a warning in the manual that stated, the more you higher the sound the quicker it got damage and develop low output
just a guess, but it is likely a component failure in the audio amp circuit.
Some serious troubleshooting must be done.
I don't think so, I have the same problem, same dgx 220, low volume out, if their is a problem in the circuit I would notice some anomaly or distortion or noise. Even at 127 sound level, the sound is good, clear, no distortion, just low volume. Maybe only 50% of other model.
@josephx distortion would not necessarily accompany a low volume. Preamp volume may pass thru the final amp with no amplification or distortion. However, if you have another with the same issue, then it may be design intent.
I have already resolve the issue. I have replaced 4 resistor from the amplifier input stage, 2pc, 4.7k replaced by 100ohm, and 2pc 10k replaced by 1k. Now working better.
@josephx Hi, can you specify the resistor number according to the diagram to be able to identify it, I'm trying to fix a DGX-620 with the same issue and i'm trying to get your solution right to apply it there. According to the info you provided and compared with service repair we are talking about R503 and R514, I can't find the later and the others are R610, R821, R827 which ones? Thanks for your help.
Laurel, you could ask your technician to replace 4 resistors at the amplifier board. 2pc 4.7k just infront od the amplifier ic, replace 100ohm. And 2pc 10k replace by 1k, under the ribbon wire.
Hi, I've a keyboard Yamaha PSR S550 with low output(volume) but after checking the DM board using multimeter, I found out that some smd capacitor have low charges and could that be the source of the problem before I tampering with the board please.
Just got it sorted! My volume was low as heck. I turned off the piano and did a factory reboot. (Not necessary thou but i just bought this used today) Basically held the far right key down and then turned it back on.
THEN.....hit the function button then Use the white "arrows up" button under the big black knob. Push the arrows up button until the screen reads TouchSns. (Prob 6 pushes) When you see that, use the big black knob and circle it to the right until you get to number 4 on the screen which removes the soft touch. NOW your keys should be loud as heck! You're welcome!!
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 4,712
To laurel, are you the first owner of the keyboard? Does it has the same volume level, the first time you use it? Or does it happen only lately?
crwdns2934271:0crwdnd2934271:0 Josephdgx220 crwdne2934271:0
