Oral-B Braun Toothbrush Motor Not Working
I have the following toothbrush: Oral-B Braun Genius X Type 3771
The toothbrush can be fully charged, battery lights are working normally. It can be switched on, all indicator lights are working, pressure sensor light is working fine, timer light is also working.
The problem only is that it just won’t spin/vibrate. I’ve replaced to a new toothbrush head, but still doesn’t work. No humming/sound from the body at all.
I am willing to attempt to repair it by myself. My questions are:
- I’m suspecting motor problem inside, is this correct?
- Is it repairable?
- Is there a guide?
Thanks for your time. Hope you’d help me out.
Hello together,
I have a similar problem.
When the toothbrush is out for 5 or 10 minutes I'm able to turn it on, at the most times.
It goes on for about 2-3 seconds.
After that, it goes off. The light is still on. But nothing happens anymore.
Sometimes i car turn it on again, sometimes not...
The SMD is okay, the battery is fully charged with 3,88 V.
Any ideas?
crwdns2934271:0crwdnd2934271:0 el-barto21 crwdne2934271:0
@el-barto21
I would start with a new battery.
Even though it shows the correct voltage this doesn't mean that it is OK when under load.
You may be measuring the open circuit voltage and not the voltage when it is "working"
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
I have the same problem and I can see how the motor stop working. They design the thoothbrush head to have hole so that it will go down the metal rod to the motor which lead to killing the motor in 2 or 3 years of use.
crwdns2934271:0crwdnd2934271:0 ThisPersonShow crwdne2934271:0
