3rd generation Time Capsule, model A1355. Released in October 2009.
How do I replace power supply with external supply?
In the Time Capsule Overall page it says under upgrades:
Power Supply:" You can replace and or repair the power supply or remove the current power supply by adding a stand-alone power supply.
But there is no information on how to do this. The Model 1302 section says how to take the supply out, but not how to fix / replace it. I was given a 1355 that supposedly worked but I get no LED when I plug it in, so I suspect a power supply issue. How do I hook up an external supply either permanently or to verify that the rest of the unit works?
https://sites.google.com/site/lapastenag...
Very good description of how to fix as far as I can tell. I'm not sure if I still have unit, as it's been a while since I asked, and I may have gotten rid of it. If I can find it will give this a try
Unfortunately the website in this answer is no longer active.
That's not a problem ;-) check it here:
https://web.archive.org/web/202103141628...
FYI: web.archive.org has many of the webpages that are no longer active.
Cheers!
LDS (LazyRock)
Arthur Torrey crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,375
