The Samsung Galaxy A31 is a mid-range Android device released by Samsung in April 2020. Identifiable by model numbers SM-A315(F, F/DS, G/DS, and G/DSL).
Why is my phone not charging?
My samsung a31 phone not charging
crwdns2889612:0crwdne2889612:0 7
Solw charging
3 month ago in my phone no charge
=== Update (08/09/23) ===
No no charge is there in my phone
My phone is dead thanks
crwdns2933315:06crwdne2933315:0
Well, mobile is not charging is mainly happen because of the bad charger. Now the first thing you should do is to change the charge and then if it is not working then the charging jack of your mobile phone can be the cause replace it from a mobile repairer Your mobile will get starting charge.
الهاتف دائما يعيد التشغيل والشحن يسقط بسرعة
Try to reset it if it didnt work change the battery
Well you can try the following it might help you out:
  1. Check your charger.
  2. Run a test using Samsung Members.
  3. Clean the charging port.
  4. Check for water and moisture.
  5. Reboot your device.
  6. Update your software.
  7. Check for damage.
لماذا هاتفي دائما ما يقفل ويعاد تشغيله والشحن من ممتلئ الي شحن صفر
Some times my mobile not charging, after restart the phone it starts charging
Why my phone is not charging
My phone charging not fast
muhdyusuf4693 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,658
