Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
crwdns2934591:0163crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Can I repair a Wireless XBONES CNTLR using parts from CNTLRModel 1697?
Hello!
I’ve got a Wireless Xbox One S Controller (1708) with a missing right trigger assembly and a damaged left analog stick input (barely working, does not move properly) and I was wondering,
Would it be possible for me to repair the Wireless XBOne S Controller (1708) with parts from the Wireless XBone Controller (1697), since they’re using similar parts?
Could I disassemble the Right Trigger assembly on Model 1697 and then reassemble the Right Trigger Assembly on Model 1708, using the parts from the disassembled Model 1697 Right Trigger Assembly?
Could I also use the left analog stick input from Model 1697 and install it on Model 1708?
I believe they are not interchangeable. However if you have both taken apart just check if they fit, im not sure if they used the same triggers but if they did there should be no reason they wouldn’t interchange.
sean.vikman crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 46
