Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
Horrible grinding sound when spin cycle ends.
After washing a blanket my washer made this awful grinding noise as the spin cycle stopped. Thinking it was just strain from a heavy sopping wet blanket I gave it a rest and tried a small load of clothing the next day. To be clear the washer still spins, agitates and carries on as normal all the way up to the spin cycle. Its not spinning enough to wringe out the clothes they're still soaked but it does spin. When the spin cycle ends it comes to a slow halt and makes this banging and grinding sound. What part could it be and what should I look for when I take this thing apart?
it sounds like it has a break problem. BUT there is also a part inside the stem called a drive block that will cause your symptoms.
https://www.youtube.com/watch?v=w4O3n3r9...
Thank you, the video was very helpful. I'm not sure if this will fix it, as I have yet to make time to take this bugger apart but I will make sure to inspect the drive block along with other parts. Hopefully this is a cheap fix; I'm not looking to lug it down the stairs if I have to junk it.
tube spins but not in balance.when washing does not acatate
Amber Cote crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 5,171
