The Bose SoundLink Mini II is a Wireless Bluetooth Speaker that delivers high quality audio from a compact design. The device weighs approximately 1.5 pounds and has a Bluetooth range advertised up to 30 feet. The device was released after June 26, 2015 and is Identified by model number 725192-1110.
There is little or no response from the buttons
I get a small flash of light from the power/charge indicator when I disconnect the USB Charger. I get similar response if I disconnect the cradle supply but only if the USB is plugged in as well. Some devices see the Bose through Bluetooth but do not connect.
Battery tests good.
The speaker doesn't power on.
Did you tried this solution?
Bose Soundlink Mini II Microschalter / Tasten Reparatur
Paul Lakin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 88
