The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
Why does my left controller stick have drift?
I was playing the walking dead: saints and sinners for the first time and I noticed I was slowly strafing to the right. I took it as the game's push mechanic and just kept playing. I then hopped onto vrchat, and truly noticed the stick drift. I haven't seen any repair guides for the quest’s controllers, so I'm wondering if anyone knows a fix?
crwdns2889612:0crwdne2889612:0 11
crwdns2944067:05crwdne2944067:0
I have been having this too. I push forward and then i start walking backwards, either down through menus or when I'm walking around. blowing on it helped for a few weeks until it didnt. im dreading sending it in because i use my quest 2 every day.
Same here, whenever I use VRChat it would move backward or sometimes left or right, which makes it impossible to move in the direction I want to move.
I am having the same issue in Resident Evil 4 and Pavlov, actually every game where I need to use movement (Left controller thumbstick). If anyone know how to fix it please share. I'll be greatful.
Not sure what to do for sideways stick drift but i have front/back stick drift on my left controller, i switched my thumbsticks so itd be my turning stick since it doesnt drift sideways, rolling the thumbstick while pressing it in also seems to work for short periods of time.
Left controller stick drift usually happens when the joystick’s internal sensor wears out or becomes dirty, causing unwanted movement even when you aren’t touching it.
Cleaning around the stick, recalibrating the controller, updating firmware, or replacing the joystick module can often fix the problem.
You could try spraying in some deoxit fader f5 around the edges of the . (or any other contact cleaner that contains carbon dust) I did that on my joy cons for my switch and it fixed the issue.
Lalt Papal crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 4,318
