The Jura Impressa S85 includes a range of programming keys and a digital screen on its front face. The machine is designed to brew either one medium cup or two small cups of coffee.
crwdns2934591:02crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Jura S9 Loud 'pop' and then water from the bottom
Recently, over several weeks, the water flow from my Jura S9 has been poor. Very slow to dispense coffee and sometimes the stream even stops and restarts. Today, while dispensing, there was a loud pop, like a circuit breaker popped. I could hear sizzling after that. The machine kept going, but no more coffee came out. After that, I tried a rinse cycle. It ran, but the water came out from the bottom instead of the spout.
There are no error messages displayed. It doesn’t seem to know it’s broken.
I opened the covers. There is a host that exploded. I assume where ever it outputs too is blocked.
Is this repairable? What do I replace? (aside from the tubing that busted)
I’m curious if Ms. Shaheen ever solved this problem. My machine just made loud pop and I took back panel off and the exact same hose has ruptured and I am wondering if I simply replace it, if the same thing will happen again.
I did it attempt to repair it in the end, so I do not know what it will take. Good luck and let us know how it goes. -m
Sorry, it's a little bit late. Try to open and revise the brewing unit using this guide, especially the drainage valve. The hose itself can easily be replaced. Think also of the outlet valve (the one with the black cap, visible in your foto), look for this guide.
crwdns2886500:0Siemens Surpresso compact Outlet valvecrwdne2886500:0
crwdns2930805:0crwdne2930805:0
Siemens Surpresso Outlet Valve repair
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
crwdns2886500:0Jura Impressa S85 Brewing unitcrwdne2886500:0
Jura Impressa S Model Brewing Unit Removal
crwdns2942205:01crwdne2942205:0:
Thank you. Just now saw this, but I did end up getting rid of the machine. Still makes me sad.
Hello ! I have exactly the same problem, and now after replacing the broken hose it still doesn't work : no more coffee came out and there is a leak on the back, coming from here :
So I assume that the broken hose wasn't the problem...
If someone has the solution I would be very grateful !!
Maybe it is a broken connector like this one? https://www.ebay.de/itm/294963640494
I finally succeeded : a o'ring was missing on the connector
Thanks for your help !
Mary Shaheen crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,037
