The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
Accidental spill inside storage reservoir.
Hello,
I need some guidance. I was filling the tank but I dropped the funnel and spilled water outside the water compartment and into the storage compartment. Water started to pour out from the sides of the unit and from the bottom. I haven’t turned the unit on since I don’t know if I should wait to that water to dry. What should I do? Please advise!!
honestly…. if it spilled in there and you didnt have it plugged in i would try and flip the unit on its side and get as much of the water out just with gravity. once youve done that either you can take a hair dryer and let it run for a little bit (be sure to not melt the plastic if there is any on the unit) or just let it sit for a day or so and dry out.
Laura crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 262
