The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
iPad won’t turn on with on off button
iPad won’t turn screen on unless it’s plugged into a charger and reconnect battery
wont turn on screen with on off switch only
battery shows 100%
Update (04/21/2021)
The connection is fine for a n off switch
That connection is all good
There’s a connector for the power flex cable that’s not too far from the power button itself make sure that’s not damaged.
I’ll check it out
However that button does turn the screen on and off but will not power up on a full shut down
The only way to power it up is to disconnect the battery then reconnect it
That only works when plugged into a charger
Battery alone wont turn it on
Battery show 100%
Then starts up as normal
Anyway appreciate the reply I’ll have a close look at the connector you mentioned
Kindest regards Gerry
seems ok i cleaned it put a meter on it to check if they're connecting that seemed ok
Gerry Golden crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 73
