Repair and disassembly guides for the Nintendo Switch OLED Model, announced and released in 2021.
Right JoyCon buttons not working at all
I have the newer generation switch in grey if that’s important, and the right joycons buttons are not working at all. The joystick movement is still recognized by the console and the sync button on the joycon still works. Every other button has no effect at all. I have my controllers up to date, my system up to date. My left controller is completely fine. I also did have the issue a month ago where the joycon was pressing random buttons on its own, which i never fixed and so i left my switch and have come back to this problem. Please help me.
Update (04/05/21)
Nevermind, I left it for like 4 hours and it seems to be fine now. Not a fix but if nothing else works letting it be might work
Shut up I can’t believe this. Same problem and hit it about 4 times at a decent strength but not enough to do any damage and the buttons work now. That’s crazy. Thank you everyone!
crwdns2933315:020crwdne2933315:0
Dude.i had The same problem like You and i started to investigate here but i couldn't find an answer, i just got súper frustrated and i smashed My joycon to the floor, funny thing is that now My problem has been solved after that and My joycon is now working perfectly, i broke The Stick but is not drifting. Now i'm gonna Stick The joystick back to it's place cause i don't want to deal with that again
Legit bro try this but dont hit it too hard
it also worked for me wtf
Can confirm, I had the same issue. Tried percussive mantaince, not proud of it, but it worked
I put the controller in a bag and smacked it into the wall. It works now. I'd suggest wrapping the joystick so you don't break it.
Percussive maintenance for the win 🤣
This same thing is happening to me but it is in fact my LEFT joy con, and it’s so frustrating to not find any answers. No buttons work except for the joystick itself. I’ve also left it docked for days, everything is updated, and no the buttons are not stuck and need to be cleaned with a %#*@ toothbrush. I’m just left wondering if I need to buy some more joy cons.
I literally was so angry, I wrapped my joy con in my t-shirt and hit it against my wall, it worked. But how many times will I have to do this before the joy con breaks completely is the question. I think the only solution is to get a new one but I cannot find the grey ones anywhere and it’s so annoying!!! Still wondering why this exact same thing is happening to everyone
It’s been a while since this question but in case any other people recently get the same problem here’s what I did to fix it:
  1. Go to system settings
  2. Go to “system” and make sure everything has the latest updates.
  3. Go to “Controllers and sensors” and press “update controllers”
  4. After it’s done reset the non responding controller by pressing the SYNC button once and then pressing another button to turn it on.
After this it should be working and if not try to check if maybe the controllers feel sticky or stuck when pressing them, you might have to clean them. If none of that works it’s probably best to get a new one.
Dude..everyone here has tried that.
I had the same problem today, did all the updates and restarts still had the problem, smacked it against my hand 3 times after searching for a solution and it worked… was also my right side buttons not inputting, joystick worked fine for a little till it needed smacked again
I had the same issue until I unscrewed the back part of the joycon..my guess is a cord got unplugged inside of the joycon or something is to tight or loose or something.
I am having the same issue. Right controller, analog stick works, but no buttons at all are registering. I read through this forum and decided trying to bang it against my hand a few times as a last ditch effort and it actually worked. I am shocked and also thankful that I found this thread!
Where exactly on the controller did you bang it? Over the buttons? On other side of butttons? How hard?
I literally have the same problem right now. I panicked last night, non of the right buttons work except the joystick. I’ve updated my joycons, my whole Nintendo, but they still don’t work. Someone said on a different website to leave it be for a while or couple of days so I’m gonna wait. It’s crazy that we all have the same problem and it’s the RIGHT joy con as well. I’m wondering what causes it:/ you both made me less worried, I’ve been looking for answers and solutions everywhere and I couldn’t find anything
Same thing you described! Only the joystick of the right controller is working! I let it sit for a day in the dock, I updated everything in the system settings, and it still isn’t working. I will pass on throwing it against the wall for now. Maybe I’ll try docking it for another few days?
I was having a similar issue but my fix was to constantly have the right joycon connected to a power source
Tried the smash solution. Worked perfectly! My buttons started to respond again after punching my thigh with the joycon. It's just like the good old TV slapping days.
I just got the funlab luminous joy pads. It's 3rd party. The only issue is the + button doesnt work when in hand held mode. If I take it off it works. I can't figure out what's wrong. I think I'll try smacking it see if that works. Ant other ideas??
I just hit that thing on my thigh a bunch of times and it works! amazing🤣
Re seat ribbons hope works, left joy on wasn’t working took it apart re sat ribbons worked except for broken button so far did it again this morning cause only stick was working, but now buttons do too had issue with both let the charge to full then unscrewed an re seated the ribbons seems to be working now
I just resat all of the ribbons on the one I was fixing, same issue as everyone else on this thread, and that did the trick for me. One of the ribbons that had a little flip cover had come loose I believe- the cover completely popped off when I got down to its layer so I reattached the cover and resat the ribbon and it worked. (Also turned out that the controller wasn’t up to date but updating it didn’t solve the issue. Unfortunately “percussive maintenance” didn’t work for this one for me.)
It's a lose cord inside of it. I've unscrewed it and screwed it back on and it worked and that was after I've completely took apart my joycons to replace the shell. So my guess is it's a lose cord
i had the same problem for few months ago, so when i looked up in the comment, all i have to do is to smacked the side for couple times. and its worked!
My girlfriend read this thread and stoically threw their controller across the room. It started working.
made an account JUST to be able to answer this, and i had the same exact problem as yall, my red/right joycon wasnt working😭
was really against and scared to thwack it off the wall, but after a useless 20 sec tutorial, and scrolling through the comments, my impatience won
it worked via thwacking, just do it gently💀
My left joycon analog stick works but none of the buttons work. Random smacking it did nothing.
Opened the joycon to check if there was any loose connections, but it doesn't seem like it. After disconnecting all ribbon cables, I would expect the at least the directional buttons would work alongside the analog stick.
My guess is that the motherboard needs replacement?
video of the joycon
https://youtube.com/shorts/Jxh6oW_ZbV4
Just dropped it in my carpet 3 feet. Works now, omg. Thanks guys
I know this is old but I had the same problem as OP. Beat around on my joycon and got it to work intermittently by pressing around on the joycon. Took it apart and narrowed it down to the R button. Oddly enough, when the ground connection is severed, it causes all of the buttons to not respond. So open your joycon and check your L and R buttons and maybe even your ZR and LR buttons as well. Replacing mine fixed the issue. Requires micro soldering.
Bruh, I was having the same problem with my nintendo sitch oled Red joy con (the right one). I went to a repair shop and they were like we cant fix this and told us to buy a new $60! Joy con. We refused and took it home. I left it for some days and after a while i took it saw the answers in this website. So i decided to smack the joycon slightly on my wooden bed which after two smacks fixed it. I was very greatful and it saved me 5000 rupees or 50 dollars. Try this but be careful when smacking it dont do it too hard, do it gently. I hope this helps anyone like me who will come to this website.
Daumurai crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 68
crwdns2936753:030crwdne2936753:0 277
crwdns2942667:0crwdne2942667:0 30,509
