Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
crwdns2934591:040crwdne2934591:0 crwdns2934593:0crwdne2934593:0
cracked front glass panel and hinge
how do i fix my lenovo Y50-70 touch version the front glass panel cracked and i cant close the laptop risking cracking the screen itself. because the hinge came lose from the screws.
Hi,
You will have to nearly completely dis-assemble the laptop so that you can replace the LCD unit as it appears looking at the manual that the glass panel is part of the LCD panel and not a separate component. Doing this will also allow you to tighten the hinge screws.
Here’s the hardware maintenance manual for the laptop.
Go to p.65 to view the necessary pre-requisite steps and then the procedure to remove the LCD panel.
On p.95 Item #3 you will find the FRU number (part number) for the two types of LCD panels available for the model. Depending on which type you have, search online using the part number only to find suppliers of the part that suit you.
Usually the part number can be found on the back of the LCD panel somewhere if you wish to verify that you’re ordering the correct one.
If doing this yourself seems too daunting, contact a reputable, professional laptop repair service and ask for a quote.
Evan Fisher crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 55
