Jura XS95 - coffee amount too small
Thanks in advance for the advice!
I have a used Jura XS95 that only makes about 1/3 of a portion of coffee before the rest of the hot water leaks into the drip tray.
When the cycle starts, coffee flows into the cup as normal. After about a third of a cup, the coffee flow trickles off and hot water begins to leak out of the bottom of the brew group into the drip tray.
I have disassembled, cleaned, lubed, and replaced all the seals in the brew group. I have replaced the drainage valve and the lower piston.
I have changed the grind density from fine to course and back again with no change in problem. I have used pre-ground coffee in the bypass as well with no change to the problem.
I have run out of ideas,.... Thanks for the help!
I have this same issue - although mine began after I ran both decalcify and descaling processes.
It was filling a full cup as normal, but now it only fills 1/3 cup.
Looking forward to hear if anyone has a solution!
