Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Detached screw mounts - can I re-attach them
Hi …. I repaired my wife’s iPhone 5S and in the process of doing so a couple of the ‘mounting/receiving luggs’ for the plate that sits over the screen connectors detached themselves from the plate they were adhered to (see images) ….. is there a recommended method/adhesive I can use to re-attached them ? The plate is in place an held by two screws at the top currently
Thanks
If I’m not mistaken those are standoff points that are soldered directly to the board which would require micro soldering tools to fix but you should be fine to leave them as they are. Just make sure you’ve retrieved any loose bits to ensure no damage is done after the repair is completed. I’ve had lots of phones come in without the shields or screws present and they work perfectly fine. They’re just there to make sure the connects don’t disconnect on impact but I have yet to see them disconnect from an impact.
Keith Joslyn crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 31
