No steam coming out of my steam generator iron
Morphy Richards steam generator iron has stopped steaming
Steam comes out only if I push the steam button, not by itself. I did de cleaning program several times, also with vinegar
My steamer isn't steaming I tried putting vinegar in water in it still will not steam
Hi Susan,
Your steam vents might be clogged. You need to descale the iron. You can either buy descaler solutions or make your own. The simplest and most cost effective way is to mix distilled vinegar and distilled water 50/50 in a cup and use it as a solution.
Make sure you unplug the iron beforehand. Also empty the water container in the iron.
Pour the solution in the iron. Look at the bottom of the iron where the vents are and use a toothbrush or a bamboo skewer to clean the holes.
Switch on the iron and set it to max heat, let the solution heat up and dissolve the limescale that possibly have built up in your iron until it starts flowing through. Burts the steam out good number of times until it stops producing little sand-like particles. You can do this over a thick towel.
Then unplug your iron and pour out the remaining descaler/home made solution and wipe off the soleplate once it cooled down.
Thankyou so much will try to do that now
Thanks but it didn't work for me
Burts into burst
Please my low water indicator light is on but I have full water as such my iron is not steaming, what should I do? I need help
It's a steam generator, so there is no water tank on the iron to empty or descale, I have descaled the iron plate, but the problem I would suggest is in the base unit, or the pipe. When I press the button to ask for steam it makes the appropriate noise for a brief period 10 seconds and then nothing happens, then the noise stops completely. is it possible that the pump is blocked and if so how can you descale it?
is it getting hot enough? It must be set past the minimum steam temp and reach that temp..........assuming there is water in it.
I have applied a of the above , although my iron is on ( it's not hot yo touch) everything is hot. My iron won't go to descale light .What am I doing wrong?
There is water in it with the vinegar as advised
There is water in it with the vinegar as advised Have done all that you have advised
Stem not comming
If your steam generator iron isn’t giving off steam, try this:
  1. Descale it – Limescale buildup is a common issue. A mix of vinegar and water can help clear it out.
  2. Make sure it’s hot enough – It won’t steam if it hasn’t reached the right temperature.
  3. Check the water tank – Refill it or try resetting the iron, even if it looks full.
  4. Press the steam button – Some models only release steam when the button is held down.
If none of that helps, it might need servicing.
Susan Carroll crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 66
crwdns2936753:030crwdne2936753:0 264
crwdns2942667:0crwdne2942667:0 21,362
