Repair guides and support for hair irons, also known as hair straighteners.
Why iron gets too hot?
My Iron getting too much Hot, the hair getting burn with extremely temperature! Pls Help how could i get repair or solution.
Hi @karnawal ,
What is the make and model number of the flat iron.
It could be the temperature sensor in the iron or the iron’s temperature control circuit.
The iron would have to be opened and tested to find out what the problem is.
The hard part may be finding suitable replacement parts if it is a faulty component as sometimes the device may be designed to be non-repairable by the manufacturer and no spare parts are available, but you can only test it first to know what the problem is.
You will need to have a DMM (digital multimeter) and know how to use it and also have some knowledge about electronic circuits and components.
Thanks for your kind reply. Model number: PS
ASIN: ASINB00V9SY2T2, can i open it myself at home and repair it? I mentioned the model number and ASIN, i think that details could make you understand and able to share me the tips to get repair. Thank you
When searching for the model this is what I found so hopefully yours is the same, maybe just rebranded.
Looking at images there are screws holdiong it together and not hidden clips but i can't see all of it. You may have to undo the screws and disassemble it and then you need to have a DMM (digital multimeter) so that you can test if the heater element and thermostat are OK by using the Ohmmeter function of the meter. That way you don't need to connect the power to the iron as this could be dangerous.
You would need to know how to test electronic circuits using a DMM and know what the different components look like and what they do.
If you don't know then it will be very difficult for you
Karnawal crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 202
